I'd love to be able to fade colors and temperature like brightness level. Either holding a button to ramp or press a button to add a value to the current status. As far as I can tell there's no way to currently do this within Hubitat.
Some drivers support passing an optional rate
key to the setColor()
map, besides the standard hue
, saturation
, and value
keys. This will let you specify, in milliseconds, the duration of the transition. This how the built-in Groups and Scenes app manages to do this if you specify a transition time for the scene. You can also do it from a rule (with a custom command, I think--I don't think the "standard" action supports rate
) or a custom app. For example:
setColor([hue: 0, saturation: 100, level: 100, rate: 5000])
...will change to red (hue 0, saturation 100) at 100% over 5 seconds.
However, not all drivers support this, and this only handles color, not color temperature. And as mentioned above, many apps don't really provide a way to specify rate here either, nor is it apparently a "standard" key in this parameter (it's not documented, and I only know about it because I've looked at Hubitat's example drivers and the reason it was added to them).
So, your feature request certainly still stands. Personally, I wish there were even more options here, like the ability to specify a color temperature and a level all in one command, which for some devices would make sending these commands less chatty and possibly more reliable. But, in the meantime, you might not be 100% out of options.
(I should note that you could also use a custom app or rule to fade/transition something over time via either built-in or manual actions, but that's not quite like having something built in to the driver.)
