Hi, I moved from a home with neutral to non-neutral home; I can't reuse majority of the switches except two inovelli red. I took them with me. I also took a few ZigBee sonoff S31 plugs. I did not unpair the other zooz switches due to time constraints. So if I factory reset the hub, would it cause any issues with ghost nodes or present an issue if I re-include the inovelli and sonoff?
You probably just need to do a Soft Reset without restoring a backup... that resets the Hubitat DB to "empty"
Then reset the radios:
Settings then Zwave Details or Zigbee Details.
Now you're back to factory fresh, without having to do all the New Hub Registration steps.
