Factory Reset and Unable to Register
Hubitat Elevation C-8 Pro
I am in an endless loop trying to register my C8 Pro after a factory reset. I can locate it using LAN or MAC address. My Account works but shows no registered hubs.
can you find the hub IP address on your LAN? Use angry IP scanner.
You could try pressing the network reset hole on the bottom near the edge, it has a different shape(round) vs. the other 100 tiny holes(square). It’s not at all obvious that there is a switch there. It’s located on the edge nearest the ethernet & USB-C power port
