Ezeelum Factory Reset
C8-Pro Latest os
Does anybody know how to factory reset a..
Ezeelum # 6 inch Smart Recessed Light, Zigbee Upgraded Stable Connect, 15W RGBWW 2700K-6500K Dimmable Ceiling Lights
I certainly can't find a button on the device...support doesn't answer...all I get is a message that simply says nothing but leave a message. :rage:
from what I'm seeing the reset pattern should be 5 on/off transitions within 3 seconds.
Thanks...I googled all kind of stuff and could find it. I'll give that a try. If you get a chance...where did you find that. It's not in the user manual I have?
First place I saw it was buried in an Amazon review.
Awesome. That did work. I had to use the flash command set to 500ms to get the Homeseer switch to oscillate that fast...but it worked.
Great to know. THANKS!!!
That reset method is great ...Unless you have multiple can lights on the same circuit...in a highly vaulted ceiling.
Again ...thanks!
:rofl:
