Will it be possible to extend command retry logic to valves?
I am currently doing this via repeats in rules to ensure that valves are open or closed, and it would greatly simplify my automations if command retry logic could be used.
Thanks!
Thanks!
Yup, I can add them, open and close only, ignoring anything switch related. Do they report immediately on receipt of command?, or is there a transition time involved..., and if so what's a safe value.
Thank you!
Everything below is for the Zooz Titan Valve Actuator, with the built-in driver for it.
There is a transition time involved - whether the valve is paired using Z-Wave or Z-Wave LR.
Based on the event log below, I would suggest that 10 seconds is a safe value between receipt of command and the status changing:
I'm curious how a retry may play out WRT to the Titan's (optional) self-test... That test just moves the lever ~1/4 open, then back (not full open).
Now I can't recall approx when my self-tests run, so I'm of course not able to find any log activity that would indicate what those commands look like
I'm not seeing self-test associated status changes for any of my three Titan actuators. Maybe @agnes.zooz can comment on whether the self-test generates z-wave events.
P.S. Even if it did generate events, the likelihood of the testing time (which occurs once in 14 days) intersecting with a hub-generated command is kinda slim, no?
Update should be in 2.4.1.168, there was a bug in it in 167
I do have on my long to-do list to properly implement supervision in my ZAC36 driver. It actually sends back a supervision reply with "working" status (per z-wave spec) so I would know right away if the device got the command or not. If no timely response I could send a retry. Potentially a little more reliable than the platforms retry.
I fleshed it out better for my universal driver (vs what was in the dimmer/switch drivers) so I should be able to take most of that and use it on other drivers now.
FYI: the Leaksmart valve driver and @kkossev ’s tuya valve driver both implement a switch on/off as well as valve open/close, so I have been using the command retry with them since it rolled out to beta. Not sure what the change will mean for these devices.
