Expired WebCore certificate(SOLVED)
Hello, I was wondering if anyone could help me to resolve an issue that has just started today please.
Since 15:41 today, I have not been able to create any new pistons or register a browser.
I get this issue on my apple ipad and also my android phone. I am running webcore on my hubitat hub.
IMG_1506
Kindest Regards,
Nathan
Doesn’t appear to be a webCoRE issue…
It is probably a webcore issue as other users are reporting issues with getting the register code on the webcore forum.
tagging @nh.schottfam
Interesting dashboard.webcore.co loads fine for me…
It appears to fail from within the webcore smartapp when you select Register a Browser.... you get a blank screen. the webcore dashboard is fine except when you try to create a new piston. :slight_smile:
I cannot comment on the ST side.
On HE, everything works in my tests.
Typically starting with logout in the browser and from their is my suggestion.
If ST is having a problem someone needs to check the platform and groovy code are running ok
Thanks for all the responses. I have checked both my devices today and my webcore issues are now gone.
Download the Hubitat app
