After successful migration from C-5 to C-8 here are some things I noticed which have all since resolved themselves in the C-8. The C-5 was powered down after I did the cloud backup, so it was not a factor.
When the C-8 (@ ver 2.3.5 platform) first was pulling in the cloud migration from the C-5 I had a kind of light show. ;-P. My Leviton Zigbee wall switches which we on (non dimmer) started going crazy. Turning on and off very rapidly in a random pattern. I got annoyed so I went over and physically hit the off switch on them.
Asking to do a software platform upgrade while running 2.3.5 download went extremely slow and ultimately failed. Tried three times. After giving up, I asked for a reboot and tried again. This time the download went very fast and succeeded in upgrading to latest 2.3.6.
After rebooting into 2.3.6 on the C-8:
My Sonoff ZBMINI switches, the first gen which require a neutral wires, decided to drop off the map. About 12 of them. Doing a Zigbee add new device operation brought back 3/4 of them (found previously paired devices). Doing it again, brought back more. A third time, seems to get them all. I hope they stay connected. So far so good.
I had a zigbee Light Group 2.1 composed for some dimmers. 3 smart bulbs and a Leviton zigbee wall dimmer. I had noticed a new option in the grouping was set called "command mixed devices?" was set. I don't remember this option and I don't remember setting it. It was working fine with the option. Turning off the option however, made the Leviton wall dimmer not cooperate with the group device. So I switched this "command mixed devices" back on. Not sure what it does exactly, but kudos to the Hubitat team to turning it on for me. I assume by comparing what kind of devices were in the grouping?
Played around with the Zigbee rebuild option and TX radio power and after giving it 24 hours the mesh seems to be strong again as it was when I had the C-5. Things "seem" faster to respond. I have about 120 zigbee devices. Nice.
CPU load shows the hub 2x higher then when I had the C-5. Memory usage also seems to be a bit more in the C-8 vs the C-5 when first starting up. However, the rate at which the memory drops seems to be a lot more stable. Seems to be holding at the same level once it stabilizes. Hopefully, this will prevent my need to reboot daily like I was with my C-5 due to memory leaks. fingers crossed
Overall, I am happy with it so far. I'll probably keep my C-5 around as a backup, just in case I need to
buy another C-8 and need to do the migration again. Lock my C-5 in an environmentally controlled safe place.
