Super old message, but I thought I would reply because I was already troubleshooting some HTTP stuff and could give it a try.
You can fix it either of a couple of ways:
queryString has a capitalization error in your sample. However, note that I got an HTTP 408 error, not no traffic. Maybe something has changed or been fixed since your testing, though. I'm on hub platform version 2.2.1.115 as I write this.
- use
query instead with a map of the terms. I prefer this method because it's easier for me to not screw up the queryString.
Either of these worked for me:
queryString
def traceRandomCode(number)
try
def postParams =
uri: "https://postman-echo.com/post",
requestContentType: 'application/json',
contentType: 'application/json',
queryString: "type=info&title=From+GUI&tag=email",
body : ["body": "foo"]
logDebug("$postParams")
asynchttpPost('myCallbackMethod', postParams)
catch(Exception e)
if(e.message.toString() != "OK")
log.error e.message
def myCallbackMethod(response, data)
logDebug("response.status = ${response.status}")
if(!response.hasError())
logDebug("response.getData() = ${response.getData()}")
[dev:3544](http://10.0.0.4/logs#dev3544)2020-07-10 02:32:32.408 pm [debug](http://10.0.0.4/device/edit/3544)response.getData() = {"args":{"type":"info","title":"From GUI","tag":"email"},"data":{"body":"foo"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","x-forwarded-port":"443","host":"postman-echo.com","x-amzn-trace-id":"Root=1-5f08c253-2ac58ce6f4e1437a447f8aba","content-length":"14","accept":"application/json","content-type":"application/json","user-agent":"Apache-HttpClient/4.5.2 (Java/1.8.0_181)","accept-encoding":"gzip,deflate"},"json":{"body":"foo"},"url":"https://postman-echo.com/post?type=info&title=From+GUI&tag=email"}
[dev:3544](http://10.0.0.4/logs#dev3544)2020-07-10 02:32:32.395 pm [debug](http://10.0.0.4/device/edit/3544)response.status = 200
[dev:3544](http://10.0.0.4/logs#dev3544)2020-07-10 02:32:32.003 pm [debug](http://10.0.0.4/device/edit/3544)[uri:https://postman-echo.com/post, requestContentType:application/json, contentType:application/json, queryString:type=info&title=From+GUI&tag=email, body:[body:foo]]
query
try
def postParams =
query: [type: "info", title: "From+GUI", tag: "email"],
catch(Exception e)
log.error e.message
[dev:3544](http://10.0.0.4/logs#dev3544)2020-07-10 02:34:51.800 pm [debug](http://10.0.0.4/device/edit/3544)response.getData() = {"args":{"type":"info","title":"From+GUI","tag":"email"},"data":{"body":"foo"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","x-forwarded-port":"443","host":"postman-echo.com","x-amzn-trace-id":"Root=1-5f08c2de-7a96d9a321bb61b1c1f7e0fb","content-length":"14","accept":"application/json","content-type":"application/json","user-agent":"Apache-HttpClient/4.5.2 (Java/1.8.0_181)","accept-encoding":"gzip,deflate"},"json":{"body":"foo"},"url":"https://postman-echo.com/post?type=info&title=From%2BGUI&tag=email"}
[dev:3544](http://10.0.0.4/logs#dev3544)2020-07-10 02:34:51.780 pm [debug](http://10.0.0.4/device/edit/3544)response.status = 200
[dev:3544](http://10.0.0.4/logs#dev3544)2020-07-10 02:34:51.293 pm [debug](http://10.0.0.4/device/edit/3544)[uri:https://postman-echo.com/post, requestContentType:application/json, contentType:application/json, query:[type:info, title:From+GUI, tag:email], body:[body:foo]]
