Anyone up for some driver work?
* EverSpring ST814
* modified by lgkahn 2015, added parameters for timeout, and temp changes,
* also add color to battery percent, and icons for humidity and temp. Make primary temp display larger.
* original timeout was 5 minutes .. This is too often when putting in cold environment like freezer.
* That is why I made the timeout configurable. And also change the default to 180 minutes.
* V4 some bug in recent release of smartthings ide made saving impossible if you make the parameters
* required kept saying please fill out all fields, even though they were so changed it.
* Version 2. Just set my second one up and temp is innacurate so add offset temp and humidity to fix.
* also limit temp to 1 place after the decimal. Also add more colors for temp for the lower ranges.
* version 3 lgk, added tile to show last update time, in case it is not working you will know at a glance.
* Version 3a default values are not working correctly so put code in to set inputs if null, also put in
* correct time zone ranges -12 to 14 according to wikipedia.
* lgk version 4 figured out how to do time without user input of time zone and works correctly for daylight saving etc.
* lgk version 5. Fix for how smartthings changed the way labels are displayed.
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata
definition (name: "EverSpring ST814 V3", namespace: "lgkapps", author: "@Ben chad@monroe.io and lgkahn")
capability "Battery"
capability "Temperature Measurement"
capability "Relative Humidity Measurement"
capability "Configuration"
capability "Alarm"
capability "Sensor"
command "setBackLightLevel"
attribute "lastUpdate", "string"
fingerprint deviceId: "0x2101", inClusters: "0x31,0x60,0x86,0x72,0x85,0x84,0x80,0x70,0x20,0x71"
* 0x31: COMMAND_CLASS_SENSOR_MULTILEVEL_V2
* 0x60: COMMAND_CLASS_MULTI_CHANNEL_V2
* 0x86: COMMAND_CLASS_VERSION
* 0x72: COMMAND_CLASS_MANUFACTURER_SPECIFIC
* 0x85: COMMAND_CLASS_ASSOCIATION_V2
* 0x84: COMMAND_CLASS_WAKE_UP_V2
* 0x80: COMMAND_CLASS_BATTERY
* 0x70: COMMAND_CLASS_CONFIGURATION_V2
* 0x20: COMMAND_CLASS_BASIC
* 0x71: COMMAND_CLASS_ALARM
preferences {
input("TempChangeAmount", "number", title: "Temperature Change Amount?", range: "1..70",description: "The degrees the temperature must changes before a report is sent?", defaultValue: 2,required: false)
input("HumidChangeAmount", "number", title: "Humidity Change Amount?",range: "5..70" ,description: "The percent the humidity must changes before a report is sent?", defaultValue: 5,required: false)
input("ReportTime", "number", title: "Report Timeout Interval?", description: "The time in minutes after which an update is sent?", defaultValue: 180, required: false)
input("TempOffset", "number", title: "Temperature Offset/Adjustment -10 to +10 in Degrees?",range: "-10..10", description: "If your temperature is innacurate this will offset/adjust it by this many degrees.", defaultValue: 0, required: false)
input("HumidOffset", "number", title: "Humidity Offset/Adjustment -10 to +10 in percent?",range: "-10..10", description: "If your humidty is innacurate this will offset/adjust it by this percent.", defaultValue: 0, required: false)
simulator
/* messages the device returns in response to commands it receives */
for( int i = 0; i <= 100; i += 20 )
status "temperature ${i}F": new physicalgraph.zwave.Zwave().sensorMultilevelV2.sensorMultilevelReport(
scaledSensorValue: i, precision: 1, sensorType: 1, scale: 1).incomingMessage()
status "humidity ${i}%": new physicalgraph.zwave.Zwave().sensorMultilevelV2.sensorMultilevelReport(
scaledSensorValue: i, precision: 0, sensorType: 5).incomingMessage()
status "battery ${i}%": new physicalgraph.zwave.Zwave().batteryV1.batteryReport(
batteryLevel: i).incomingMessage()
tiles
valueTile("temperature", "device.temperature", width: 2, height: 2) {
state("temperature", label:'${currentValue}°',
icon: "http://cdn.device-icons.smartthings.com/Weather/weather2-icn@2x.png",
backgroundColors:[
[value: 1, color: "#c8e3f9"],
[value: 10, color: "#dbdee2"],
[value: 20, color: "#c0d2e4"],
[value: 32, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 92, color: "#d04e00"],
[value: 98, color: "#bc2323"]
valueTile("humidity", "device.humidity", inactiveLabel: false) {
state "humidity", label:'Humidity\n ${currentValue}%', unit:"",
icon: "http://cdn.device-icons.smartthings.com/Weather/weather12-icn@2x.png",
backgroundColors : [
[value: 01, color: "#724529"],
[value: 11, color: "#724529"],
[value: 21, color: "#724529"],
[value: 35, color: "#44b621"],
[value: 49, color: "#44b621"],
[value: 50, color: "#1e9cbb"]
standardTile( "alarm", "device.alarm", inactiveLabel: false )
state( "ok", label:'BAT OK', action:'alarm.on', icon:"st.alarm.alarm.alarm", backgroundColor:"#00cc00" )
state( "low", label:'BAT LOW', action:'alarm.off', icon:"st.alarm.alarm.alarm", backgroundColor:"#e86d13" )
valueTile("battery", "device.battery", inactiveLabel: false) {
state "battery", label:'Battery\n ${currentValue}%', unit:"",
[value: 20, color: "#720000"],
[value: 40, color: "#724529"],
[value: 60, color: "#00cccc"],
[value: 80, color: "#00b621"],
[value: 90, color: "#009c00"],
[value: 100, color: "#00ff00"]
standardTile( "configure", "device.configure", inactiveLabel: false, decoration: "flat" )
state( "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure" )
valueTile("status", "device.lastUpdate", width: 2, height: 1, decoration: "flat") {
state "default", label: 'Last Update: ${currentValue}'
main( ["temperature", "humidity"] )
details( ["temperature", "humidity", "alarm","battery", "configure","status"] )
* parse incoming device messages and generate events
def parse(String description)
def result = []
def get_battery = false
def cmd = null
if ( description == "updated" )
log.debug "event description: ${description} - updating battery status"
get_battery = true
else
cmd = zwave.parse( description, [0x20: 1, 0x31: 2, 0x70: 1, 0x71: 1, 0x80: 1, 0x84: 2, 0x85: 2] )
if ( cmd != null )
if ( cmd.CMD == "8407" )
result << zwaveEvent( cmd )
log.debug "cmd.CMD=8407; result=${result} - updating battery status"
get_battery = true
else
result << createEvent( zwaveEvent( cmd ) )
if( get_battery == true )
def last = device.currentState( "battery" )
/* device wakes up roughly every hour */
def age = last ? (new Date().time - last.date.time)/60000 : 10
log.debug "Battery status was last checked ${age} minute(s) ago"
/* don't check too often if woken up more frequently */
if( age >= 10 )
log.debug "Battery status is outdated, requesting battery report"
result << new physicalgraph.device.HubAction(zwave.batteryV1.batteryGet().format())
result << new physicalgraph.device.HubAction(zwave.wakeUpV1.wakeUpNoMoreInformation().format())
log.debug "Parse returned: ${result} for cmd=${cmd} description=${description}"
return result
* event generation
def zwaveEvent(physicalgraph.zwave.commands.wakeupv1.WakeUpNotification cmd)
[descriptionText: "${device.displayName} woke up", isStateChange: false]
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpNotification cmd)
def zwaveEvent(physicalgraph.zwave.commands.alarmv1.AlarmReport cmd)
def map = [:]
log.debug "AlarmReport cmd: ${cmd.toString()}}"
if(( cmd.alarmType == 2 ) && ( cmd.alarmLevel == 1 ))
log.info "${device.displayName} powered up!"
return map
else
/* alarmType == 1 && alarmLevel == 255 means low battery, else ok */
map.value = cmd.alarmLevel == 255 ? "low" : "ok"
map.name = "alarm"
map
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv2.SensorMultilevelReport cmd)
log.debug "SensorMultilevelReport cmd: ${cmd.toString()}}"
def map = [:]
switch( cmd.sensorType )
case 1:
/* temperature */
// log.debug "try4"
BigDecimal offset = settings.TempOffset
def startval =convertTemperatureIfNeeded(cmd.scaledSensorValue, cmd.scale == 1 ? "F" : "C", cmd.precision)
log.debug "scaled scaled sensor value = $cmd.scaledSensorValue scale = $cmd.scale"
log.debug "offset = $offset"
log.debug "startval = $startval"
def thetemp = startval as BigDecimal
log.debug "the temp = $thetemp"
def newValue = (Math.round(thetemp * 100) + (offset * 100)) / 100
BigDecimal adjval = (thetemp + offset)
def dispval = String.format("%5.1f", adjval)
def finalval = dispval as BigDecimal
map.value = finalval
//map.value = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmd.scale == 1 ? "F" : "C", cmd.precision)
map.unit = getTemperatureScale()
map.name = "temperature"
def now = new Date().format('MM/dd/yyyy h:mm a',location.timeZone)
sendEvent(name: "lastUpdate", value: now, descriptionText: "Last Update: $now")
break;
case 5:
/* humidity */
map.value = (cmd.scaledSensorValue.toInteger() + settings.HumidOffset)
map.unit = "%"
map.name = "humidity"
break;
createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd)
def map = [:]
map.name = "battery"
map.value = cmd.batteryLevel > 0 ? cmd.batteryLevel.toString() : 1
map.unit = "%"
map.displayed = true
map
def zwaveEvent(physicalgraph.zwave.Command cmd)
log.debug "Catchall reached for cmd: ${cmd.toString()}"
def configure()
// default values not working trying to set implicitly if null
if (settings.ReportTime == null)
settings.ReportTime = 180
if (settings.TempChangeAmount == null)
settings.TempChangeAmount = 1
if (settings.HumidChangeAmount == null)
settings.HumidChangeAmount = 5
if (settings.TempOffset == null)
settings.TempOffset = 0
if (settings.HumidOffset == null)
settings.HumidOffset = 0
log.debug "ST814: In configure timeout value = $settings.ReportTime"
log.debug "Temperature change value = $settings.TempChangeAmount"
log.debug "Humidity change value = $settings.HumidChangeAmount"
log.debug "Temperature adjust = $settings.TempOffset"
log.debug "Humidity adjust = $settings.HumidOffset"
sendEvent(name: "lastUpdate", value: now, descriptionText: "Configured: $now")
delayBetween([
/* report in every 5 minute(s) -- lgk change all to use settings */
/* lgk override to save battery set report as defined in preferences */
zwave.configurationV1.configurationSet(parameterNumber: 6, size: 2, scaledConfigurationValue: settings.ReportTime).format(),
/* report a temperature change of 2 degree C */
zwave.configurationV1.configurationSet(parameterNumber: 7, size: 1, scaledConfigurationValue: settings.TempChangeAmount).format(),
/* report a humidity change of 5 percent */
zwave.configurationV1.configurationSet(parameterNumber: 8, size: 1, scaledConfigurationValue: settings.HumidChangeAmount).format()
// lgk update function ... ranges not working in inputs so still need this
def updated()
log.debug "in updated"
// fix interval if bad
if (settings.ReportTime <1)
settings.ReportTime =1
log.debug "Time Interval too low... resetting to 1"
if (settings.ReportTime > 1439)
settings.ReportTime = 1439
log.debug "Time Interval too high ... resetting to 1439"
// fix temp change amount
if (settings.TempChangeAmount < 1)
log.debug "Temperature Change Amount too low... resetting to 1"
if (settings.TempChangeAmount > 70)
settings.TempChangeAmount = 70
log.debug "Temperature Change Amount too high ... resetting to 70"
// fix humidity change amount
if (settings.HumidChangeAmount < 5)
log.debug "Humidity Change Amount too low... resetting to 5"
if (settings.HumidChangeAmount > 70)
settings.HumidChangeAmount = 70
log.debug "Humidity Change Amount too high ... resetting to 70"
// fix temp offset
if (settings.TempOffset < -12)
settings.TempOffset = -12
log.debug "Temperature Offset too low... resetting to -12"
if (settings.TempOffset > 14)
settings.TempOffset = 14
log.debug "Temperature Adjusment too high ... resetting to 14"
response(configure())
