Eventstream broken in Release 2.4.3.133
the parse() function is not called.
eventStreamStatus() gets called on start/stop etc.
the eventstream connects and is sent data
as I viewed the connected server logs
eventStreamStatus() called - START: EventStream Started
I rolled firmware back to 2.4.3.131 and it is working
i will update again to 2.4.3.133 to confirm
did update to 2.4.3.133, parse() not being called
rolled back to 2.4.3.131, all WORKING
so confirmed, 2.4.3.133 has broken by code that uses interfaces.eventStream.connect()
did i post this in the right forum?
I'm having the same issue, any hope for a fix soon?
at this point some acknowledgement from Hubitat would help
Tagging @support_team from Hubitat to make sure they are aware of this reported issue.
We are looking into it, but there have been no recent changes.
@bobbyD
I just updated to 2.4.3.137
and lost callbacks into parse, but I had a hunch
changed the rawData to true
in my initialize()
interfaces.eventStream.connect(url, [
pingInterval: 10,
readTimeout: 60,
headers:["Accept": "text/event-stream"],
rawData: true
// data from eventStream
void parse(String response) {
log.debug("parse(): ${response}")
and sure enough, parse() now gets called
when I was at 2.4.3.131 & rawData: false, parse() string would be:
parse(): { "upTime": 24915162, "freeHeap": 116376, "minHeap": 45084, "wifiRSSI": "-39 dBm, Channel 6" }
now its like the backend isnt preparsing message data
here is the result when rawData set to true:
parse():
parse(): data: { "upTime": 25795256, "freeHeap": 113324, "minHeap": 45084, "wifiRSSI": "-40 dBm, Channel 6" }
parse(): event: message
so get
  1. event:message
  2. data: { "upTime": 25795256, "freeHeap": 113324, "minHeap": 45084, "wifiRSSI": "-40 dBm, Channel 6" }
  3. empty string
rawData:false is what i want to use, as the JSON at that point ready to parse
sse.dev
is a good site to test against this
i have written a driver that does and only when rawData: true
does it call parse()
 * interfaces.eventStream tester
import groovy.transform.Field
@Field static def shouldReconnect = false
metadata {
    definition(name: "EventStream-Tester", namespace: "MJS Gadgets", author: "MitchJS", importUrl: "") {
        capability "Initialize"
        command "disconnect"
        attribute "eventStreamStatus", "string"
        attribute "networkStatus", "enum", ["offline","online"]
preferences {
def initialize() {
    log.debug("initialize() called")
    // temporally prevent reconnection
    if (device.currentValue("eventStreamStatus") == "Connected") {
    sendEvent(name:"networkStatus", value: "offline")
    sendEvent(name: "eventStreamStatus", value: "Connecting", descriptionText:"${device.displayName} eventStreamStatus is Connecting")
    log.debug("initialize() called, request subscribe to SSE")
    try {
        // SSE test url
        url = "https://sse.dev/test?interval=5"
        log.debug("initialize() subscribing to events via interfaces.eventStream.connect(${url})")
        // connect to SSE
            pingInterval: 10,
            readTimeout: 60,
            rawData: false
    catch (Exception e) {
        log.error "initialize() Execption: ${e}"
        runIn(10, initialize)
def disconnect() {
    log.debug("disconnect() called")
        shouldReconnect = false;
        interfaces.eventStream.close()
    log.debug("parse() ${response}")
def eventStreamStatus(String message) {
    log.debug("eventStreamStatus() ${message}")
    if (message.startsWith("START:")) {
        sendEvent(name:"networkStatus", value: "online")
        sendEvent(name: "eventStreamStatus", value: "Connected", descriptionText:"${device.displayName} eventStreamStatus is Connected")
        shouldReconnect = true;
    else if (message.startsWith("STOP:")) {
        sendEvent(name: "eventStreamStatus", value: "Disconnected", descriptionText:"${device.displayName} eventStreamStatus is Disconnected")
        // try to reconnect
        if (shouldReconnect == true) {
            log.debug("eventStreamStatus() will re-init")
            runIn(5, "initialize")
    else if (message.startsWith("ERROR:")) {
        if (message.contains("SocketTimeoutException")) {
            // try to reconnect
bump
When is the last time you re-tested? There were some changes in recent builds (not sure if they are still in beta) that may help.
im running 2.4.3.137
and the rawData: false results in no callbacks to Parse()
the demo code i posted will show that
There are newer betas currently in testing. I would wait for a release next week (assuming you are not in beta), re-test, and follow up if the problem still happens then.
yes, im not in the "beta" and i can wait
i added a bunch of code to get it working
It started working after 2.4.3.149 update :slight_smile:
well... its not 100% right
as you can see now parse() is called twice!
should only be called with the actual JSON
not the "data :" prefix when i set rawData to false
but its NOW closer to prior behavior!
// connect to SSE
    pingInterval: 10,
    readTimeout: 60,
    rawData: false
progress is good :slight_smile:
thanks HE team!
@bobbyD
It's exactly the prior behavior now. Once we started getting enough reports to determine it wasn't a fluke, the changes got rolled back. The changes made it through both internal testing and beta, but if it causes problems, it goes.
Ok... so now i test, and its only calling parse() once!
like it should
strange, i swore it called in twice :slight_smile:
and i screen shot it...
the good news it is working like it should
thanks
Mitch
