@bptworld love the setup of your apps and appreciate the hard work and care that obviously goes into them. I have a quick question/issue on the directional conditions in EE.
The problem with this condition specifically (and separately, humidity setpoint > humidity direction) is I don’t see any option or explanatory text about reversal options like I would when a different condition is used.
My understanding is that the reversal of a cog does the same action, just in reverse, but I’m not sure what to expect with this cog and what, if anything, will trigger the reverse.
Useage:
I’d like things to happen when someone comes down the stairs (eg. Stairwell motion, then downstairs motion; right) then have something else happen when someone goes back up the stairs.
Can this be accomplished with 1 cog or do I need to make a second for the upstairs direction? Also good to take into consideration that I’d like something different to happen on the reverse (going upstairs).
Thanks for any help!
