EvaLogik Smart Plug Dimmer ZW39 Stops powering lamp after device config update using Hubitat's built-in EVA LOGIK Smart Plug Dimmer driver
Hubitat hubVersion : 2.3.2.141
EvaLogik Smart Plug Dimmer ZW39 v.1.0d Date Code : 0421 FW : 2.02
Highlights:
I have had this problem with 2 different dimmers however a third is working as expected with the same driver/settings.
Steps to duplicate:
- Hubitat Zwave Include
- Plug-in ZW39 Dimmer and it will begin flashing fast.
- Hubitat recognizes the device and asks if we want to Include with security - I always choose No.
- Hubitat brings-in the device with the built-in "EvaLogik Smart Plug Dimmer" driver and I name it and provide a room.
- I wait about 30 minutes for the Zwave network to build neighbors for the device before testing.
- Initial testing looks good; the device responds and can be dimmed.
- Since this driver provides some of the additional features mentioned in the EvaLogik manual I make the following changes:
Pulled from Hubitat device logs:
Hold Dimming Duration(#11) from null to 4
Push Dimming Duration(#10) from null to 0
Maximum Brightness(#9) from null to 99
Minimum Brightness(#8) from null to 1
Dimming Duration(#7) from null to 5
LED Indicator(#1) from 0 to 1 - I hit Config to update the device.
debugHold Dimming Duration(#11) = 4
debugPush Dimming Duration(#10) = 0
debugMaximum Brightness(#9) = 99
debugMinimum Brightness(#8) = 1
debugDimming Duration(#7) = 5
debugPower Recovery(#6) = 2
debugAuto On Interval(#4) = 0
debugAuto Off Interval(#2) = 0
debugLED Indicator(#1) = 1 - Now the Device indicates its working both by the LED and Hubitat Zwave responses, but No power is sent to the light.
- Things I've tried:
Obviously tried pressing the physical button and changing the Hubitat device's levels with no joy.
I tried switching to a Generic Zwave Dimmer driver.
I tried Using the Hubitat User: "Basic Zwave Tool" driver to reset the advanced features to Default via the EvaLogik manual.
I tried Excluding the Device - Resetting it to Factory and Including it back in with no joy.
Now I have 2 of these that don't work and 1 new in a box that I don't dare try.
Any advice is welcome.
