Platform Version 2.4.3.167
Hardware Version C5
Item: EVA Logik ZW97 Outdoor Smart Plug (2 channel)
Issue: Initial problem that one of two plugs working
I am at an impasse. Trying to use the ZW97 for the lights this year's decoration and noticed only one of the plugs working as scheduled.
Tried to exclude then include--- could not so. And thru the hub forced override to remove it.
Have tried to reset--- holding for 10 seconds; clicking for 5 times and unplug for 30 seconds. Shutdown hub waiting 30 seconds. Tried to just include and plug in device to rejoin...
All resulting in nothing but frustration. Is it possible I bricked this? And if not any suggestions on steps to get this fixed?
To return the device to factory defaults, click the button twice quickly then hold for at least 10 seconds or remove it from the host connection.
Reset and include again.
Check for ghosts leftover from any unsuccessful pairings before you invest any time going at the device again... If you have ghosts, you're never going to make reliable progress until they are removed.
Add to Z-Wave Network
-Put zwave interface controller into "add" mode, triple press the program button. It will be included. Once it is confirmed- refresh the Zwave network to optimize performance)
Remove from Z-wave
Put Zwave into "Remove" and tripple press and program to exlude
To return to factory- click button 2 times quickly and hold for 10 seconds.
