Hi! I'm brand spanking new to Hubitat. Saw a couple of EVA LOGIC devices on the Hubitat compatibility list and so I hastily purchased this EVA LOGIK Smart Light Dimmer Plug (model ZW39), which I now see is in fact not on the list (eh - doh!). However, the plugs simple on/off sister-device (model ZW36) is on the list.
Before I return it, I was wondering if maybe there is in fact a way to get Hubitat to work with it. Hubitat finds it on the network. Pressing the "configure" button in the Hubitat device options causes the LED light on the plug-in to blink. Hubitat device settings "Current States" shows instant feedback of the Switch being on or off as I manually turn it on and off, however, I can't control the unit using Hubitat. I have the device selected as an EVA LOGIK Smart Plug using the Dimmer template. Using the physical button on the plug-in, I can confirm that the device works as intended with on/off and dimming. As I'm using the device driver for the more simple, on/off plug, I don't have any dimming commands to test out in.
I feel like it's so close to working. Is there maybe a generic device driver that I could use to make this work? Or would I be better off just returning it and picking something up that is 100% compatible?
Thank you kindly for any advice you can offer.
