I was attempting to add it to HomeKit, but even after toggling the “HomeKit Enabled”, it doesn’t show anywhere in the HomeKit Inegration app (Neither under “Garage Door Controller” or under “Ignored Devices”, “Incompatible Devices” or any other category…)
So, I’m at a loss… The driver seems to have all the necessary attributes, but there is likely something else that I should be looking for but haven’t…
That's not enough though, those things should have been fleshed out. You'll get errors trying to run it because although it now says it has a switch capability, there's no On or Off to respond. They are aliases to Open and Closed I suspect, but I didn't try touching the code since I'd have nothing to test with.
