I'm trying to migrate my old Domoticz server to Hubitat. Most things are running fine, but I wonder if anyone tried to communicate with ESP Easy devices? They work great with Domoticz, but I can't find any examples for Hubitat.
It should be possible to control them using commands from Rules or if someone wanted to make a more specific driver to do more with them. But if you just want to send them commands over HTTP then I would recommend setting up a few Rules to send the commands you are interested in to the devices in question.
I think It is easy to control a relay or similar from Hubitat to ESP Easy via a http request. My main goal is to read sensor data from Esp Easy. I use moisture sensors to remind me when to water my plants, so I want EspEasy to send data to Hubitat and trigger a rule when I need to add water.
