I have setup a notification that when switch closed on the door sensor it signals notifier that the door is open. Sometimes works sometimes not. Most times not. Also I have that when open it repeats notification after 10 minutes. Never worked. I use Pushover. I have attached a copy of the logs. I am not a programmer so I don't know what the debug is telling me.
Are you doing anything with those power and energy reports? If not, disable those reports or at least increase their thresholds.
That's probably unrelated to your problem, but chatty devices can cause reliability issues and/or delays...
How do I disable the reports? Is it the Text Logging on the device?
If you open the parent Zooz Double Plug device and any other metering devices you should see reporting interval and/or threshold settings.
I think those settings in the double plug have a disabled option, but a lot of devices don't so for those you can increase the numbers so that they don't send reports as often.
This is only if you're not doing anything with those values that requires you to see those changes.
It looks like your contact sensor is also sending both types of open/closed reports which could cause problems so you should enable the duplicate related setting.
That prevents them from appearing in the logs, but doesn't stop them from being sent by the device so that won't help.
