What error message are you seeing? You should provide some screenshots of logs and any relevant information about what you have tried before you saw the error .
Also, is it the same error you are referring to here?
If so, I would suggest just posting about this in one place.
I was mostly offering general advice, and gave not been following this issue. From what I have seen on this topic and the other topic, as @thebearmay explained on both these topics, a manual update is required for the code at the moment.
Ultimately it may be best for @csteele to confirm my interpretation.... He has commented about the next platform update possibly including something to help resolve the timeout error
Understood. Wanted to just inform of the issue happening with the latest 1.0.89 update. Plus I believe there was another recent HE update that included extending the webcore timeout issue.
Will continue to update manually as necessary until a fix is issued.
Hi ! I followed the steps to manually update it and it seems to work, however the HPM is still showing a 10.0.88 version ,. How do I get rid of this? is that a real issue? how do I clear that ?
Thank you for the help
