Here's my code:
In the parent app (relevant snippets)
` @Field Integer earlyFetchMinsDefault = 30`
input name: "earlyFetchMins", type: "number", title: "", required: true, defaultValue: earlyFetchMinsDefault
def getEarlyFetchMins() {
log.trace "in get early fetch mins"
if (earlyFetchMins) return earlyFetchMins
else return earlyFetchMinsDefault
in the child app:
Integer earlyFetchMins = parent.getEarlyFetchMins()
When the child app calls parent.getEarlyFetchMins(), the log is this:
With this unhelpful error message:
Is there a problem with trying to use a default value for a setting that the user has not set yet? How does one go about having a default value that the user can optionally adjust, but still being able to use that value if the user never adjusts it?
