Error on setHeatingSetpoint on Heatit Z-TRM3
Not sure if this is correct place to post this but I'm using Home Assistant as a frontend for Hubitat. I have 4 Heatit Z-TRM3 thermostats and they work well with the built in driver. However, from HA, I can't change the temperature. I get this error message java.lang.NullPointerException: Cannot invoke method scale() on null object on line 196 (method setHeatingSetpoint), on/off function works fine. If I set the thermostats to "Generic Z-wave thermostat" it works fine.
Is this potentially a bug in the driver?
I can add that the reason why I don't just use the generic driver is that the Z-TRM3 seems a bit finicky when using that one. It seems to hang from time to time and not update according to the setpoint but with the Z-TRM3 driver I haven't had any issues.
Possibly.. I’ll check it out
Fixed in release coming
Hi. I get the error below when trying to control the Heatit controller using rules and the same driver. Is there a fix for this please?
Unexpected Error
An unexpected error has occurred trying to load the app. Check Logs for more information.
Error: Lexing failed on line: 1, column: 2, while reading 'o', no possible valid JSON value or punctuation could be recognized.
Can you post the rule?
As soon as I add the underfloor heating control the error comes up.
Will
Processing: 1000007119.jpg…
@bcopeland are are you able to take a look at this please
Sorry… I think the reply got buried in my community notifications.. Checking
Found the problem.. Will get a fix out.
Amazing thank you
Hi @bcopeland this isn't in the 2.3.8.134 update or which one should I look out for?
Hi @bcopeland i am still not able to control the underfloor heating with rules. I have the latest update, when can i expect the fix please?
Will
This fix is in 2.3.9 which is in beta right now.
Hi @bcopeland
I am now running 2.3.9.180 and get the following when trying to run the rule above:
Unexpected Error
Error: The JSON input text should neither be null nor empty.
Please would you take another look
Will
Hi @bcopeland have you had chance to take another look please
Will
