Error, invalid operand type
Hi, I've recently seen this error in my logs, I don't believe I used to see this, perhaps related to the upgrade to 2.3.6?
I have an app that sets the hub variable SumpHiPwrT1 to now in seconds. The variable is declared as type number.
Hub variable
The error seems to be related to a second app that uses the hub variable as a trigger.
Any ideas?
That's odd. I will look into this...
Was just looking at my logs and I am seeing the same error. It's occurring in two rules , both with a similar triger as OPs. In my case it's humidity sensor increase.
Found and will be fixed...
@brad @bertabcd1234 The .144 update fixed my problem.
I am running .144 and problem still persists.
Can you elaborate on this by including a screenshot of your rule, and a screenshot for the logs generated when the rule runs?
I am using latest Rule Machine app.
Temperature sensors are:
  • endpointId: 01
  • application: 05
  • manufacturer: LUMI
  • model: lumi.weather
  • modelType: Aqara WSDCGQ11LM
Errors:
app:7582023-10-17 12:32:08.660errorinvalid operand type for 20.95(number) decreased 20(number)
app:7582023-10-17 12:32:08.655errorinvalid operand type for 20.95(number) decreased 20(number)
app:7512023-10-17 12:11:43.304errorinvalid operand type for 20.56(number) decreased 20(number)
As a consequence trigger is not working.
I tested this with the same Aqara sensor and ended up with the error. It's weird that it works several times before getting the error.
Just realized I am still getting this error as well. For me it is a Humidity increase. Just noticed mine is a bit different. As the final part in () says string? not number.
Rule trigger:
Fix for this in next release.
