When I try to edit any existing set of Trigger Events, I get an "Unexpected Error" page. When I look at the logs, I see this error:
2020-09-06 07:28:22.385 pm [error](http://192.168.1.4/installedapp/configure/399)java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String on line 873 (selectTriggers)
I deleted them and started over. I tried different things and I noticed they were all copied from another rule and modified, not sure if that was the problem. The ones not copied worked as expected.
