Error 500 issue
HI,
I have a C7 hub and theses days it was slow on just navigating between app and devices... not sure if its related or something but now, when I try to access app or anything it tells Error 500
Not sure on why and what to do...
Version info would be helpful. Also, when was your last backup done?
In General, error 500 is a generic internal server error. If you can get to the settings page, I would do a reboot with advanced options and click on database rebuild.
If you cannot get to settings, I would go to the diagnostics page (Hubitat Diagnostic Tool | Hubitat Documentation), and do a shutdown. Once it is shutdown gracefully, unplug it for 30 seconds and plug it back in. Hopefully, once it comes back up, you can get back into settings.
Then do the reboot with advanced settings, database rebuild.
You might have other options if you backed up recently. But, that is where I would start.
@user3930 to add to Tray's advice, you can also do a Soft Reset from the Diagnostic Tool.
That was the "other options" I mentioned if they have a recent backup.
not sure on version and I just reach the diagnostic tool and reboot... but still same error after login... I ll try to shutdown few minutes to see!
Not sure on my backup too... I though it was automatic, if I remember correctly I had an option for this like each day or something... I still receive notification from the hub... just no access to anything...
I tried the shutdown... error 500
I tried to enabled safe mode same thing but the safe mode still availlable so I m not sure if it enebled it properly...
not sure on what is going on!
finally, I just do a soft reset and load backup from latest which was the one written by shutdown and it works...
Thanks for your support!
