Has anyone developed a driver for a projector, similar to my Epson 5050UB? I would even like a driver for ANY projector where I could modify code if needed to work with my Epson, although I understand that basic commands are common for many brands. All I really want to do is turn the projector on (from standby) and off as if I were using the remote control. At one time there was a driver for the UHD 51A by Optoma, but access to that driver has been removed. I could probably make the code for any telnet driver work.
I found some resources from googling. These are old, but maybe they're still relevant:
ftp://download.epson-europe.com/pub/download/3211/epson321113eu.pdf
https://epsoneu-portal2.uk.kb.net/portal/api/v1/articles/1912/data/attachments/escvp_guide.zip?source=webfile
Thank you! this is helpful.
@jeppsenc Did you ever end up making a driver for your projector?
No. I came across a good buy on a Harmony hub and I set it up to run the projector using the Harmony driver. It works OK. I am trying to set something up with a GobalCache iTach.
