I have an EPEVER MPPT Charge Controller along with a companion Wifi Serial Adapter and am wondering if anyone else might have one and have found or developed a driver for it?
They provide an iPhone app that can poll the eBox-WIFI-01 device, but only when the phone is directly connected to the device’s WIFI.
I have been able to connect the eBox to my wifi AP and can then access it with a web browser on the same network, but have not been able to see the data from it with my phone/tablet in this mode.
It is possible to get data from it in that mode however and display it on the PC:
I am hoping that there may be a driver (or app) already available to feed the data to Hubitat.
If there is nothing available, I’d be more than happy to work with someone to put one together as I unfortunately I don’t have the skill set to put one together myself...
The only thing that it doesn’t show in the app is the battery fill level. Everything else it shows. It is a great device, but their implementation could be better. Having a link to Hubitat would be a great improvement!
Unfortunately, the built-in web server doesn’t provide access to the data. Their supported option is to use the App while connecting to the device’s Wifi (it doesn’t work when the device is connected to another Wifi).
It is possible to connect to the device via PC software and a specific configuration once the device is connected to Wifi.
There is an internal web server - eBox configuration only.
I have not seen an api - but I probably wouldn’t recognize one if it was right in front of me, I’m ashamed to say...
This is one of the reasons I have not switched to HE as my home is regulated based on how much battery capacity is available. I have an epever also and currently use HE to pull data over Modbus. It will be good if someone could write a driver to make this work.
