Can a enhancement be done to allow us to select multiple devices when defining a trigger using custom attribute? I had 10+ lights that I wanted to select a custom attribute for to trigger and had to select each device and it's trigger. Its a bit time consuming.
I would like to be able to select multiple devices that share the same attributes. I would use webcore to do this quickly, but am trying my best to keep webcore automations to a minimum and strictly use built in the built-in apps.
Thanks for your consideration.
