Enhancement: Maker API Feature Request
@bravenel @bobbyD
A request for a small enhancement, I'm sorry if this has been requested previously.
Is it possible to export via Maker the room that a particular device is in? (i.e. specified in Hubitat).
For myself, I group all devices into Rooms, and I would like to carry that over (via Maker) into a dashboard.
Thank you for your consideration.
Next release.
Nice! I will absolutely make use of that feature!
Thank you!
I'll add that feature into hubiVue - so following :stuck_out_tongue:
In the process of adding Rooms support to hubiVue I have found that MakerAPI does not always include the room attribute in all API requests. Can the developers check that /devices and /devices/all produce the same attribute set ??? I can code around it, but it looks to be a bug/omission in the API
FYI
@bravenel @bobbyD
OK, next release.
Latest release added this:
