I have a enerwave PIR Sensor. I used to have these setup with a variable that I set that tells the device to stay "detected" for 2 minutes, instead of switching back to off when no motion right away. With Vera (which I am SO glad I gave up since Hubitat is so much better already) I was able to set the Variable and reconfigure the device. Is there a simple way to do this with Hubitat? I may be overlooking a easy way to do this.
I am thinking I need to write my own driver for this instead of using the Generic Motion Driver. There is a ST Driver, I am just lost how to port over. (SmartThingsPublic/enerwave-ceiling-mounted-motion-sensor.groovy at master ยท xcguy/SmartThingsPublic ยท GitHub)
