Encode Disables Habitat
How can I have my schlage disarm hubitat when I enter my code to unlock the front door?
Which Schlage Lock are you using? The Encode is a WiFi lock that doesn’t directly work with Hubitat.
I have two Schlage connect zwave locks, and use the following rule to do exactly what you mentioned:
Note I do have a 5s entry delay set in HSM just to be sure that the "disarm" rule processes through before sirens start blaring.
