Does anyone have a usable driver for this fan control switch? The generic fan control does not work and I am just now noticing that Hubitat does not seem to have a driver for this controller.
Any help appreciated.
The driver that is supposed to go with it is "GE Smart Fan Control". That said, for me that driver does not work reliably if the device is paired with S2 security.
I re-paired the device with no security (cleared all the security check boxes when pairing) and it seems to work much better with the above driver (still a bit weird in the logs, but functional nonetheless).
What you said.
i have multiple paired to my C-5 with the GE Smart Fan Control driver and it works no issues. which hub/firmware are you using?
That was it. Thank You for the information.
Just a heads up I opened support request 22005, For the weirdness in this driver. It’s been sent to engineering but it may still help to report to support your experiences with the driver as well so we can really get it fixed.
Will do - Thank You
The advice still works as I just installed an "Enbrighten" fan control and it works fine. Thank you
