Before I fry my brain experimenting...
Does anyone know what this option means in a scene?
No need to do that, just read the docs or click the "?" in the upper right that will take you there. ![]()
https://docs2.hubitat.com/en/apps/groups-and-scenes#create-and-capture-a-scene
You likely do not need to enable this option unless you have devices with prestaging enabled (which I would highly recommend against and would suggest finding another way to do whatever you have it enabled for if it was intentional). As documented, it will send an explicit "On" command to any device captured as on, which is normally not necessary, as the other commands it would send should turn the device on already.
There it is. The brain remains intact. My blindness in reading this four times over is freely admited.
