I have a Harmony Hub with Companion remote and have used various methods over time to link the Home Control buttons on it to Hubitat devices. I have used a modded version of Dan's @ogiewon community Harmony driver and am currently running an emulated Hue on Home Assistant on a Pi. But to then link that back to Hubitat devices I have to use the MQTT alpha so it is a bit convoluted. It does work fine, but it would be a lot simpler if there was some way to run a Hue Emulator app directly on Hubitat.
So, I know the Harmony Hub will find and work on an emulated Hue system as it finds the one from Home Assistant, and I know Hubitat can create some sort of emulated Hue as it used to for the Amazon Echo app, so it feels like it should be possible to get a proper emulated Hue on Hubitat.
Anyone with better coding skills than me (that's 99% of you!) fancy a challenge?
I'm very willing to test and provide any info needed from the HA Hue Emulator etc.
