Elgato Stream Deck Sensor Support
Has anyone managed to get the Stream Deck to display sensor values on the stream deck keys ?
I have managed to do it, but it's a bit of a hack using external PowerShell scripts, and I was just wondering if if was missing an easier way to achieve this ?
There is Home Assistant integration for the Steam Deck, but I don't believe there is any direct Hubitat integration. I do use HTTP get commands from the Stream Deck sent to Webcore to control things, but there is no feedback provided into the Stream Deck. I mostly use it for toggling my desk lighting / fan, so the feedback is me, seeing if the device changed like I intended it to.
I also have a desk mounted tablet, which shows a Hubitat dashboard, and provides me info at my desk as well as controls. I have this setup, so when I am working from my work PC, I can still control things (as the PC my Stream Deck is attached to is usually off when I am working). It is powered off of one of my shared monitors, and with Fully Kiosk Browser, it turns on and off automatically as I am at my desk (either work or play).
There is an integration:
@ripnet
I believe it only does switches at this point though thus reason for OP's post.
I have done it now using the Home Assistant Plugin, it's just shame the Hubitat integration doesn't currently include sensor values.
This would be great! Just bumping it up.
Would you be able to tell how you achieved it?
