hello all so i always have alot of trouble when i need to edit a rule,
i want tochange the light sensor to 8 instead of 10, and i was just gonna delete the rule and re do it as always, but seems thats should be the best way. I click on everything and cant find how to edit or change that number
Do NOT edit the rule. When the rule is displayed (not in edit mode) there will be a list of conditions at the bottom of the screen. Click on "Manage and Create Conditions" Then select the condition you want to edit. When you're done and go back to the rule it will be adjusted.
