* Rheem EcoNet (Connect)
* Copyright 2017 Justin Huff
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Last Updated : 1/1/17
* Based on https://github.com/copy-ninja/SmartThings_RheemEcoNet
definition(
name: "Rheem Econet Tankless",
namespace: "billm",
author: "Bill M",
description: "Connect to Rheem EcoNet",
category: "SmartThings Labs",
iconUrl: "http://smartthings.copyninja.net/icons/Rheem_EcoNet@1x.png",
iconX2Url: "http://smartthings.copyninja.net/icons/Rheem_EcoNet@2x.png",
iconX3Url: "http://smartthings.copyninja.net/icons/Rheem_EcoNet@3x.png")
preferences {
page(name: "prefLogIn", title: "Rheem EcoNet")
page(name: "prefListDevice", title: "Rheem EcoNet")
/* Preferences */
def prefLogIn() {
def showUninstall = username != null && password != null
return dynamicPage(name: "prefLogIn", title: "Connect to Rheem EcoNet", nextPage:"prefListDevice", uninstall:showUninstall, install: false) {
section("Login Credentials"){
input("username", "email", title: "Username", description: "Rheem EcoNet Email")
input("password", "password", title: "Password", description: "Rheem EcoNet password (case sensitive)")
section("Advanced Options"){
input(name: "polling", title: "Server Polling (in Minutes)", type: "int", description: "in minutes", defaultValue: "5" )
def prefListDevice() {
if (login()) {
def waterHeaterList = getWaterHeaterList()
if (waterHeaterList) {
return dynamicPage(name: "prefListDevice", title: "Devices", install:true, uninstall:true) {
section("Select which water heater to use"){
input(name: "waterheater", type: "enum", required:false, multiple:true, metadata:[[waterHeaterList]])
} else {
return dynamicPage(name: "prefListDevice", title: "Error!", install:false, uninstall:true) {
section(""){ paragraph "Could not find any devices" }
} else {
section(""){ paragraph "The username or password you entered is incorrect. Try again. " }
/* Initialization */
def installed() { initialize() }
def updated() {
unsubscribe()
initialize()
def uninstalled() {
unschedule()
unsubscribe()
getAllChildDevices().each { deleteChildDevice(it) }
def initialize() {
// Set initial states
state.polling = [ last: 0, rescheduler: now() ]
// Create selected devices
def selectedDevices = [] + getSelectedDevices("waterheater")
selectedDevices.each {
def dev = getChildDevice(it)
def name = waterHeaterList[it]
if (dev == null) {
try {
addChildDevice("bmcgair", "Rheem Econet Tankless", it, null, ["name": "Rheem Tankless: " + name])
} catch (e) {
log.debug "addChildDevice Error: $e"
// Remove unselected devices
/*def deleteDevices = (selectedDevices) ? (getChildDevices().findAll { !selectedDevices.contains(it.deviceNetworkId) }) : getAllChildDevices()
deleteDevices.each { deleteChildDevice(it.deviceNetworkId) } */
//Subscribes to sunrise and sunset event to trigger refreshes
subscribe(location, "sunrise", runRefresh)
subscribe(location, "sunset", runRefresh)
subscribe(location, "mode", runRefresh)
subscribe(location, "sunriseTime", runRefresh)
subscribe(location, "sunsetTime", runRefresh)
//Refresh devices
runRefresh()
def getSelectedDevices( settingsName ) {
(!settings.get(settingsName))?:((settings.get(settingsName)?.getAt(0)?.size() > 1) ? settings.get(settingsName)?.each { selectedDevices.add(it) } : selectedDevices.add(settings.get(settingsName)))
return selectedDevices
/* Data Management */
// Listing all the water heaters you have in Rheem EcoNet
private getWaterHeaterList() {
def deviceList = [:]
apiGet("/locations", [] ) { response ->
if (response.status == 200) {
response.data.equipment[0].each {
if (it.type.equals("Water Heater")) {
deviceList["" + it.id]= it.name
return deviceList
// Refresh data
def refresh() {
if (!login()) {
return
log.info "Refreshing data..."
// update last refresh
state.polling?.last = now()
// get all the children and send updates
def id = it.deviceNetworkId
apiGet("/equipment/$id", [] ) { response ->
log.debug "Got data: $response.data"
it.updateDeviceData(response.data)
//schedule the rescheduler to schedule refresh ;)
if ((state.polling?.rescheduler?:0) + 2400000 < now()) {
log.info "Scheduling Auto Rescheduler.."
runEvery30Minutes(runRefresh)
state.polling?.rescheduler = now()
// Schedule refresh
def runRefresh(evt) {
log.info "Last refresh was " + ((now() - state.polling?.last?:0)/60000) + " minutes ago"
// Reschedule if didn't update for more than 5 minutes plus specified polling
if ((((state.polling?.last?:0) + (((settings.polling?.toInteger()?:1>0)?:1) * 60000) + 300000) < now()) && canSchedule()) {
log.info "Scheduling Auto Refresh.."
schedule("* */" + ((settings.polling?.toInteger()?:1>0)?:1) + " * * * ?", refresh)
// Force Refresh NOWWW!!!!
refresh()
//Update rescheduler's last run
if (!evt) state.polling?.rescheduler = now()
def setDeviceSetPoint(childDevice, setpoint) {
log.info "setDeviceSetPoint: $childDevice.deviceNetworkId $setpoint"
if (login()) {
apiPut("/equipment/$childDevice.deviceNetworkId", [
body: [
setPoint: setpoint,
def setDeviceEnabled(childDevice, enabled) {
log.info "setDeviceEnabled: $childDevice.deviceNetworkId $enabled"
if (login()) {
body: [
isEnabled: enabled,
def setDeviceMode(childDevice, mode) {
if (login()) {
body: [
mode: mode,
def setDeviceOnVacation(childDevice, OnVacation) {
log.info "setDeviceOnVacation: $childDevice.deviceNetworkId $OnVacation"
if (login()) {
body: [
isOnVacation: OnVacation,
private login() {
def apiParams = [
uri: getApiURL(),
path: "/auth/token",
headers: ["Authorization": "Basic Y29tLnJoZWVtLmVjb25ldF9hcGk6c3RhYmxla2VybmVs"],
requestContentType: "application/x-www-form-urlencoded",
body: [
username: settings.username,
password: settings.password,
"grant_type": "password"
if (state.session?.expiration < now()) {
try {
httpPost(apiParams) { response ->
log.debug "Login good!"
state.session = [
accessToken: response.data.access_token,
refreshToken: response.data.refresh_token,
expiration: now() + 150000
return true
} else {
return false
} catch (e) {
log.debug "API Error: $e"
return false
} else {
// TODO: do a refresh
return true
/* API Management */
// HTTP GET call
private apiGet(apiPath, apiParams = [], callback = {}) {
// set up parameters
apiParams = [
uri: getApiURL(),
path: apiPath,
headers: ["Authorization": getApiAuth()],
requestContentType: "application/json",
] + apiParams
log.debug "GET: $apiParams"
try {
httpGet(apiParams) { response ->
callback(response)
} catch (e) {
// HTTP PUT call
private apiPut(apiPath, apiParams = [], callback = {}) {
apiParams = [
uri: getApiURL(),
path: apiPath,
] + apiParams
log.debug "apiPut: $apiParams"
try {
httpPut(apiParams) { response ->
callback(response)
} catch (e) {
private getApiURL() {
return "https://econet-api.rheemcert.com"
private getApiAuth() {
return "Bearer " + state.session?.accessToken
