I am newbie here, overall love the platform!!. I added my Ecowitt hub and I am working on the dashboard. The temp and humidity tiles were no problem, customized the colors using Templates. There is no "pressure" tile. I added it as an attribute tile, but can't customize the color. Am I missing something? I know there is Super Tiles, Master Tiles...etc. They all seem overly complicated.
I'll try and take a look at this for you sometime in the next few days (I took over this driver recently). Happy for anyone else to jump in with suggestions or setups they have used.
Thanks for the quick reply, and thanks for taking over the driver. I do see there are some html options within the driver. Take your time
I have a feeling this more a dashboard issue in general. Being able to customize an attribute tile. No?
Yes and no. Certainly plenty of customisation options via CSS, but not based on the attribute value. Might need to think about it some more.... And get back to work
. (Me that is)
It is probably worth explaining a little more about what you want to do with the colour on the pressure tile.
If you want to set a fixed background or text colour for all attribute tiles, you can do that in the templates section under the default state. If you want to target just that pressure tile, leaving other attribute tiles unaffected, then custom CSS is probably the your best option. If you want to colour the tile based on the level of the pressure reading, separate virtual device(s) and an RM rule and some custom CSS may be required (not as scary as it may sound).
As a note, you cannot use HTML in a preference anymore so the HTML Tile Template that some drivers used to use is not as applicable. You can still use the template, just do not put HTML in it as the Hubitat will strip it out (it is removed as a security measure).
Some drivers have started doing workarounds to this (using [b] for bolding as an example).
So to start with targeting a tile to change the background color. I tried the following, it does not work.
.tile-title::after {
visibility: visible;
position: absolute;
text-align: center;
left: inherit;
right: 0;
bottom: 0;
white-space: pre-wrap;
#tile-5 .tile-title { visibility : visible !important;}
#tile-5 {backgroud-color: blue; !important;}
Nevermind, spelling error
Can you guys point me in the right direction to learn how do this?
i used smartly but added my own values for color.. you need one for every value.. this is for temp
see the layout under dashboard tile advanced
basically each of these sets the template tile color.. the state = the value of the tile being displayed.. in the case below the temp is 99 degress
"template": "temperature",
"bgColor": "#bc2323a6",
"state": "99"
"localization": "English",
"roundedCorners": 20,
"dateFormat": "MM/DD/YYYY",
"hideLabels": false,
"customColors": [
"template": "dimmer",
"bgColor": "rgba(33,100,223,0.9)",
"iconColor": "rgb(255,255,255)",
"state": "on"
"bgColor": "rgba(255,255,255,.9)",
"iconColor": "rgb(135,135,135)",
"state": "off"
"template": "motion",
"bgColor": "rgba(255,255,255,0.9)",
"iconColor": "rgb(0,0,0)",
"state": "inactive"
"bgColor": "rgba(255,248,46,.9)",
"state": "active"
"template": "switches",
"state": "on"
"state": "off"
"template": "multi",
"bgColor": "rgba(0,255,105,0.75)",
"iconColor": "rgba(0,0,0,0.66)",
"state": "closed"
"bgColor": "rgba(255,0,0,0.65)",
"state": "open"
"template": "window",
"state": "closed"
"bgColor": "rgb(251,104,14)",
"iconColor": "",
"state": "open"
"template": "door",
"state": "closed"
"template": "door",
"state": "open"
"template": "fan",
"iconColor": "",
"state": "low"
"template": "fan",
"iconColor": "",
"state": "medium-low"
"template": "fan",
"iconColor": "",
"state": "medium"
"template": "fan",
"iconColor": "",
"state": "medium-high"
"template": "fan",
"iconColor": "",
"state": "high"
"template": "garage-control",
"state": "closed"
"state": "open"
"iconColor": "",
"state": "opening"
"iconColor": "",
"state": "closing"
"template": "garage",
"state": "closed"
"state": "open"
"iconColor": "",
"state": "opening"
"iconColor": "",
"state": "closing"
"template": "shades",
"bgColor": "hsla(0,0%,50.2%,.5)",
"iconColor": "",
"state": "off"
"iconColor": "",
"state": "on"
"iconColor": "",
"state": "opening"
"iconColor": "",
"state": "closing"
"bgColor": "rgb(67,166,52)",
"iconColor": "",
"state": "open"
"template": "door-control",
"iconColor": "",
"state": "opening"
"state": "open"
"state": "closed"
"template": "lock",
"state": "locked"
"template": "lock",
"bgColor": "rgba(251,104,14,.9)",
"state": "unlocked"
"template": "water",
"state": "wet"
"bgColor": "rgba(0,243,255,0.9)",
"state": "dry"
"template": "smoke",
"state": "detected"
"state": "clear"
"template": "bulb",
"state": "on"
"template": "bulb",
"state": "off"
"template": "presence",
"bgColor": "rgba(27,176,116,0.9)",
"state": "present"
"bgColor": "",
"iconColor": "",
"state": "not present"
"bgColor": "#c8e3f9a6",
"state": "-20"
"state": "-19"
"state": "-18"
"state": "-17"
"state": "-16"
"state": "-15"
"state": "-14"
"state": "-13"
"state": "-12"
"state": "-11"
"state": "-10"
"state": "-9"
"state": "-8"
"state": "-7"
"state": "-6"
"state": "-5"
"bgColor": "c8e3f9a6",
"state": "-4"
"state": "-3"
"state": "-2"
"state": "-1"
"state": "0"
"bgColor": "#dbdee2a6",
"state": "1"
"state": "2"
"state": "3"
"state": "4"
"state": "5"
"state": "6"
"state": "7"
"state": "8"
"state": "9"
"state": "10"
"bgColor": "#c0d2e4a6",
"state": "11"
"state": "12"
"state": "13"
"state": "14"
"state": "15"
"state": "16"
"state": "17"
"state": "18"
"state": "19"
"state": "20"
"bgColor": "#153591a6",
"state": "21"
"state": "22"
"state": "23"
"state": "24"
"state": "25"
"state": "26"
"state": "27"
"state": "28"
"state": "29"
"state": "30"
"state": "31"
"state": "32"
"bgColor": "#1e9cbba6",
"state": "33"
"state": "34"
"state": "35"
"state": "36"
"state": "37"
"state": "38"
"state": "39"
"state": "40"
"state": "41"
"state": "42"
"state": "43"
"state": "44"
"bgColor": "#90d2a7a6",
"state": "45"
"state": "46"
"state": "47"
"state": "48"
"state": "49"
"state": "50"
"state": "51"
"state": "52"
"state": "53"
"state": "54"
"state": "55"
"state": "56"
"state": "57"
"state": "58"
"state": "59"
"bgColor": "#44b621a6",
"state": "60"
"state": "61"
"state": "62"
"state": "63"
"state": "64"
"state": "65"
"state": "66"
"state": "67"
"state": "68"
"state": "69"
"state": "70"
"state": "71"
"state": "72"
"state": "73"
"state": "74"
"bgColor": "#f1d801a6",
"state": "75"
"state": "76"
"state": "77"
"state": "78"
"state": "79"
"state": "80"
"state": "81"
"state": "82"
"state": "83"
"state": "84"
"bgColor": "#a6",
"state": "85"
"state": "86"
"state": "87"
"state": "88"
"state": "89"
"state": "90"
"state": "91"
"state": "92"
"state": "93"
"state": "94"
"state": "95"
"state": "96"
"state": "97"
"bgColor": "#bs2323a6",
"state": "98"
"state": "99"
"state": "100"
"bgColor": "rgba(86,58,171,0.65)",
"state": "default"
"template": "contact",
"state": "closed"
"state": "open"
"template": "bulb-color",
"state": "on"
"iconColor": "rgba(135,135,135)",
"state": "off"
"template": "carbon-monoxide",
"state": "detected"
"state": "clear"
"template": "outlet",
"state": "on"
"state": "off"
"template": "humidity",
"bgColor": "rgba(58,186,161,.85)",
"state": "default"
"template": "battery",
"state": "50"
"state": "51"
"state": "52"
"state": "53"
"state": "54"
"state": "55"
"state": "56"
"state": "57"
"state": "58"
"state": "59"
"state": "60"
"state": "61"
"state": "62"
"state": "63"
"state": "64"
"state": "65"
"state": "66"
"state": "67"
"state": "68"
"state": "69"
"state": "70"
"state": "71"
"state": "72"
"state": "73"
"state": "74"
"state": "75"
"state": "76"
"state": "77"
"state": "78"
"state": "79"
"state": "80"
"state": "81"
"state": "82"
"state": "83"
"state": "84"
"state": "85"
"state": "86"
"state": "87"
"state": "88"
"state": "89"
"state": "90"
"state": "91"
"state": "92"
"state": "93"
"state": "94"
"state": "95"
"state": "96"
"state": "97"
"state": "98"
"state": "99"
"state": "100"
"bgColor": "rgba(251,104,12,0.9)",
"state": "16"
"state": "15"
"state": "14"
"state": "13"
"state": "12"
"state": "11"
"state": "10"
"state": "9"
"state": "8"
"state": "7"
"state": "6"
"state": "5"
"state": "4"
"state": "3"
"state": "2"
"state": "1"
"state": "0"
"template": "music-player",
"bgColor": "rgba(20,20,20,.9)",
"iconColor": "",
"state": "default",
"customIcon": ""
"colWidth": 125,
"cloudRefresh": 5,
"hsmPin": "",
"hide3dot": false,
"clockMode": true,
"gridGap": 6,
"tiles": [
"template": "smartly",
"id": 0,
"device": "smartly",
"templateExtra": "{"tiles":{"0":{"id":0,"template":"thermostat","templateExtra":null,"pos":1,"mods":{"zoomable":{"value":null},"label":{"value":null},"border":{"value":null,"modifier":{"border_size":{"value":null}}}}},"1":{"id":1,"template":"thermostat","templateExtra":null,"pos":2,"mods":{"zoomable":{"value":null},"label":{"value":null},"border":{"value":null,"modifier":{"border_size":{"value":null}}}}},"3":{"id":3,"template":"dashboard","templateExtra":"67","pos":3,"mods":{"height_alignment":{"value":"full"},"buttonize":{"value":"unchecked","modifier":{"icon_only":{"value":"unchecked"}}},"icon":{"value":null},"zoomable":{"value":"1.5"},"label":{"value":"Home"},"color_fg":{"value":"rgba(255, 255, 255, 1.0)"},"color_bg":{"value":null},"border":{"value":null,"modifier":{"border_size":{"value":null}}}},"states":{"default":{"code":null,"class":""}}},"7":{"id":7,"template":"attribute","templateExtra":"lastUpdate","pos":4,"mods":{"unit":{"value":null},"numeric":{"value":"unchecked"},"title":{"value":null},"text_alignment":{"value":null},"remove_title":{"value":"unchecked"},"nudge":{"value":"unchecked"},"icon":{"value":null},"zoomable":{"value":null},"color_fg":{"value":null},"color_bg":{"value":null},"border":{"value":"rgba(0, 0, 0, 0.0)","modifier":{"border_size":{"value":null}}}},"states":{"default":{"code":null,"class":""}}},"9":{"id":9,"template":"attribute","templateExtra":"lastUpdate","pos":5,"mods":{"unit":{"value":null},"numeric":{"value":"unchecked"},"title":{"value":null},"text_alignment":{"value":null},"remove_title":{"value":"unchecked"},"nudge":{"value":"unchecked"},"icon":{"value":null},"zoomable":{"value":null},"color_fg":{"value":null},"color_bg":{"value":null},"border":{"value":"rgba(0, 0, 0, 0.0)","modifier":{"border_size":{"value":null}}}},"states":{"default":{"code":null,"class":""}}},"10":{"id":10,"template":"humidity","templateExtra":"outdoorHumidity","pos":6,"mods":{"title":{"value":"Outdoor Humid."},"text_alignment":{"value":null},"remove_title":{"value":"unchecked"},"nudge":{"value":"unchecked"},"icon":{"value":null},"zoomable":{"value":null},"color_fg":{"value":null},"color_bg":{"value":null},"border":{"value":"rgba(0, 0, 0, 0.0)","modifier":{"border_size":{"value":null}}}},"states":{"default":{"code":null,"class":""}}},"11":{"id":11,"template":"temperature","templateExtra":"battery","pos":7,"mods":{"title":{"value":null},"remove_title":{"value":null},"nudge":{"value":null},"icon":{"value":null},"zoomable":{"value":null},"color_fg":{"value":null},"color_bg":{"value":null},"border":{"value":null,"modifier":{"border_size":{"value":null}}}},"states":{"default":{"code":null,"class":""}}},"13":{"id":13,"template":"temperature","templateExtra":"outdoorTemperature","pos":8,"mods":{"title":{"value":"Outdoor Temp."},"remove_title":{"value":"unchecked"},"nudge":{"value":"unchecked"},"icon":{"value":null},"zoomable":{"value":null},"color_fg":{"value":null},"color_bg":{"value":null},"border":{"value":"rgba(0, 0, 0, 0.0)","modifier":{"border_size":{"value":null}}}},"states":{"default":{"code":null,"class":""}}},"14":{"id":14,"template":"humidity","templateExtra":null,"pos":9,"mods":{"title":{"value":null},"text_alignment":{"value":null},"remove_title":{"value":null},"nudge":{"value":null},"icon":{"value":null},"zoomable":{"value":null},"color_fg":{"value":null},"color_bg":{"value":null},"border":{"value":null,"modifier":{"border_size":{"value":null}}}},"states":{"default":{"code":null,"class":""}}},"15":{"id":15,"template":"humidity","templateExtra":null,"pos":10,"mods":{"title":{"value":null},"text_alignment":{"value":null},"remove_title":{"value":"unchecked"},"nudge":{"value":"unchecked"},"icon":{"value":null},"zoomable":{"value":null},"color_fg":{"value":null},"color_bg":{"value":null},"border":{"value":null,"modifier":{"border_size":{"value":null}}}},"states":{"default":{"code":null,"class":""}}},"16":{"id":16,"template":"temperature","templateExtra":null,"pos":11,"mods":{"title":{"value":null},"remove_title":{"value":null},"nudge":{"value":null},"icon":{"value":null},"zoomable":{"value":null},"color_fg":{"value":null},"color_bg":{"value":null},"border":{"value":null,"modifier":{"border_size":{"value":null}}}},"states":{"default":{"code":null,"class":""}}},"17":{"id":17,"template":"texttile","templateExtra":"Steam Humidifier Info:","pos":12,"mods":{"text_alignment":{"value":null},"zoomable":{"value":null},"color_fg":{"value":null},"color_bg":{"value":null},"border":{"value":null,"modifier":{"border_size":{"value":null}}}}},"18":{"id":18,"template":"attribute","templateExtra":"humidifierStatus","pos":13,"mods":{"unit":{"value":null},"numeric":{"value":"unchecked"},"title":{"value":"Status"},"text_alignment":{"value":null},"remove_title":{"value":"unchecked"},"nudge":{"value":"unchecked"},"icon":{"value":null},"zoomable":{"value":null},"color_fg":{"value":null},"color_bg":{"value":null},"border":{"value":null,"modifier":{"border_size":{"value":null}}}},"states":{"default":{"code":null,"class":""}}},"19":{"id":19,"template":"attribute","templateExtra":"humidifierLowerLimit","pos":14,"mods":{"unit":{"value":"%"},"numeric":{"value":"unchecked"},"title":{"value":"Minimum"},"text_alignment":{"value":null},"remove_title":{"value":"unchecked"},"nudge":{"value":"unchecked"},"icon":{"value":null},"zoomable":{"value":null},"color_fg":{"value":null},"color_bg":{"value":null},"border":{"value":null,"modifier":{"border_size":{"value":null}}}},"states":{"default":{"code":null,"class":""}}},"20":{"id":20,"template":"attribute","templateExtra":"heatingSetpoint","pos":15,"mods":{"unit":{"value":"%"},"numeric":{"value":"unchecked"},"title":{"value":"SetPoint"},"text_alignment":{"value":null},"remove_title":{"value":"unchecked"},"nudge":{"value":"unchecked"},"icon":{"value":null},"zoomable":{"value":null},"color_fg":{"value":null},"color_bg":{"value":null},"border":{"value":null,"modifier":{"border_size":{"value":null}}}},"states":{"default":{"code":null,"class":""}}},"21":{"id":21,"template":"attribute","templateExtra":"humidifierUpperLimit","pos":16,"mods":{"unit":{"value":"%"},"numeric":{"value":"unchecked"},"title":{"value":"Maximum"},"text_alignment":{"value":null},"remove_title":{"value":"unchecked"},"nudge":{"value":"unchecked"},"icon":{"value":null},"zoomable":{"value":null},"color_fg":{"value":null},"color_bg":{"value":null},"border":{"value":null,"modifier":{"border_size":{"value":null}}}},"states":{"default":{"code":null,"class":""}}}},"settings":{"calibration":{"devices":["lg_v20"],"devices_2col":null,"source":"\/var\/www\/html\/smartly\/assets\/data\/device_cals.json","colwidth":135,"gridgap":15,"colcount":3},"iconSize":"53","fontSize":20,"commit":"9621aa326d944b39fea8ea373ba73507a6c7d388"},"dashboard":{"mods":{"cal_devices":["lg_v20"],"cal_devices_2col":null,"header":{"value":"default"},"hide_scrollbars":{"value":null}}}}"
"rowSpan": 2,
"template": "thermostat",
"col": 1,
"colSpan": 2,
"id": 0,
"row": 1,
"device": "438"
"rowSpan": 2,
"col": 1,
"colSpan": 2,
"id": 1,
"row": 6,
"device": "291",
"templateExtra": null
"rowSpan": 1,
"template": "dashboard",
"col": 1,
"colSpan": 3,
"id": 3,
"row": 15,
"device": "0",
"templateExtra": "67",
"linkName": "Home"
"rowSpan": 1,
"template": "attribute",
"col": 3,
"colSpan": 1,
"id": 7,
"row": 1,
"device": "438",
"templateExtra": "lastUpdate"
"rowSpan": 1,
"col": 3,
"colSpan": 1,
"id": 9,
"row": 6,
"device": "291",
"rowSpan": 1,
"col": 3,
"hideUnit": false,
"colSpan": 1,
"id": 10,
"row": 3,
"device": "440",
"templateExtra": "outdoorHumidity"
"rowSpan": 1,
"col": 1,
"hideUnit": false,
"colSpan": 1,
"id": 11,
"row": 3,
"device": "438",
"templateExtra": "battery"
"rowSpan": 1,
"col": 3,
"hideUnit": false,
"colSpan": 1,
"id": 13,
"row": 2,
"device": "439",
"templateExtra": "outdoorTemperature"
"rowSpan": 1,
"col": 2,
"colSpan": 1,
"id": 14,
"row": 3,
"device": "438"
"rowSpan": 1,
"col": 2,
"colSpan": 1,
"id": 15,
"row": 8,
"device": "291"
"rowSpan": 1,
"col": 1,
"colSpan": 1,
"id": 16,
"row": 8,
"device": "291"
"rowSpan": 1,
"template": "texttile",
"col": 1,
"colSpan": 2,
"id": 17,
"row": 4,
"templateExtra": "Steam Humidifier Info:"
"rowSpan": 1,
"col": 1,
"colSpan": 1,
"id": 19,
"row": 5,
"device": "438",
"templateExtra": "humidifierLowerLimit"
"rowSpan": 1,
"col": 2,
"colSpan": 1,
"id": 20,
"row": 5,
"device": "438",
"templateExtra": "humidifierSetPoint"
"rowSpan": 1,
"col": 3,
"colSpan": 1,
"id": 21,
"row": 5,
"device": "438",
"templateExtra": "humidifierUpperLimit"
"rowSpan": 2,
"col": 1,
"colSpan": 2,
"id": 22,
"row": 9,
"device": "1810"
"rowSpan": 1,
"col": 1,
"colSpan": 1,
"id": 23,
"row": 11,
"device": "1810"
"rowSpan": 2,
"col": 3,
"colSpan": 1,
"id": 24,
"row": 9,
"device": "1810",
"rowSpan": 2,
"col": 1,
"colSpan": 2,
"id": 25,
"row": 12,
"device": "1842"
"rowSpan": 1,
"col": 1,
"colSpan": 1,
"id": 26,
"row": 14,
"device": "1842",
This is CSS?
Oh JSON. Getting a little confused, should I changed BG colors in CSS of JSON?
No. This is the dashboard structure in its JSON format. It does encapsulate the local CSS modifications. You can find it if you search it for smartly.
What is "templateExtra"?
That is additional information about the device this tile represents. For example: for a dashboard tile, templateExtra defines the specific dashboard (app number). For a link, it is the url.
I was going to suggest some virtual switches, a rule and some overlayed tiles, but seems like you have a solution, nice work @kahn-hubitat, I never knew you could define CSS for values like that, good to know...
Thanks for your help guys!
