Econet Bulldog backwards
Hello,
Has anyone had a backwards reporting zwave Bulldog valve? If so how did you fix it? @jsarcone (looks like yours is alignment, i don’t think mine is but this is driving me crazy)
I installed an Econet Bulldog at my in-laws and everything non zwave works properly. The valve points to open and closed on its physical meter, the valve will auto close if the embedded leak sensor gets wet.
But it reports backwards to hubitat on the generic zwave valve driver open when physically closed and vice verse.
Nevermind, a pin was bent in the S-video looking (remember that silly standard??) connector. Bent it back and everything started working correctly
