Two of three Ecolink tilt sensors paired great. The third one, I can't get to pair. There's a mysterious new device at the end of the z-wave details list that I assume was a result, somehow. I've tried excluding and including many times: Include/Exclue, insert battery...nothing. Light just keeps blinking.
How close to the hub are you when you try to include/ exclude?
I happen to have a ZStick S2 which I used to exclude it seemed to exclude devices I recall having issues with when they were initially installed and I had no S2. Maybe not helpful.
However I learned there is a sweet spot with regard to distance. Too close is bad for some devices. It seems to me that about 6 to 10 feet with no obstructions was the best for the devices I have.
You didn't mention, are you moving from a C4/C5 to a C7? If so you might try turning off the older hub while working on the Ecolink.
Pull the battery out of the ecolink that didn't join. Run a repair on the ghost node. After the repair click remove on the device in settings, zwave details. Check under devices as well and make sure there isn't an entry in there. If there is click on the device and scroll down to the bottom and click remove. Don't need to click force remove here if it deleted out of settings zwave details. It should go through.
Unfortunately, one of the others has not been reporting status, even though the led blinks when tilted. So, I'll probably be excluding and including another one. Maybe repair and refresh first. Hopefully, this one will go smoother.
Edit: That did the trick. So much smoother, excluding/including.
I'm having the exact same issues you were having. Moved the tilt sensor closer to the hub and exclude/include worked. Thought I was good, then I had the same status reporting issues. Thanks for posting your problem @velvetfoot and solutions @lewis.heidrick
I find that a lot of people tend to have issues with devices in the garage. Adding a repeater or wired mains powered here can help device communications back to the hub.
No doubt that is a common source of signal loss. For me, I'm very surprised to have issues with this device because I have two GE ZWave Outlets in the ceiling connected to relays that run my garage doors and another tilt sensor (that is further from the hub) that connected fine.
I have pretty weak signal out here as well. I think mine mostly stem from the breaker panel putting out a lot of electromagnetic interference and some radiant barrier stuff causing a lot of reflections. It's gotten better since I added some more devices just on the other side of the laundry room door.
In the garage I have 6 wired mains and a repeater. Garage lights, side garage door, driveway lights, workbench fan, workbench lights, and attic light switch.
Garage walls are generally insulated better to keep out the heat/cold and act as a fire barrier.
