I have an ecolink motion sensor showing motion through the led, I think in the log, but no event, and no actions in simple lighting.
The last event for motion was right before I updated to 2.15
Add me to that list
I have also had an ecolink motion sensor become inert. The hub is not receiving the reports, but it is indicated at the device. My trouble also began after the update. I suspected a unpair and pair again, will be required, but seeing this thread makes me wonder.
I have about a dozen of these guys on my mesh, only one is misbehaving in this way. However, I will state that in general, my system has begun to show signs of intermittent slowing again, after the update.
Argh, saw this thread so I decided to check my ecolink motion sensors. Iโm 0/3, and I just updated to 2.1.5 last night...
Iโm using the older, non-plus generation.
I also have a monoprice z-wave plus sensor, I forget the model # but itโs the same hardware that ecolink uses (with the pet and test jumpers on the board). Itโs using the same built-in driver, I believe, but itโs still sending events to the hub.
Edit: @mike.maxwell any thoughts? Thanks.
Hey, at least they don't do duplicate messages/events any more.
That's one way to stop it! Hahahaha
Add me to the list as well. Just updated and my 2 ecolink PIR-ZWAVE2 sensors are not working either. Just sent a request to support. I will follow this thread and see what happens.
Support has responded to the issue.
Configure didn't work. If I exclude will I have to redo all my rules etc?
Yes, you will need to redo all of your rules.
Did anyone get theirs to work? I did not and replaced the sensor.
No I did not get mine to work, I temporarily swapped out an old smart things motion sensor. I am hoping they come up with a fix. If a software update broke it, I am guessing a software update can fix it.
the issue here is the update corrected the double reporting issue, which now has broken reporting for those devices that never got configured correctly in the first place.
Reverting the change would fix the non reporting devices, and break the others, so pending some other unknown issue presenting itself we're not planning on making any changes to the driver.
If you reset and rejoin the Ecolink device and it's still not working correctly, please let us know.
Interesting I have two of these motion sensors and had no issues after the update. Confirmed that they are still reporting events correctly also.
right, and I have one as well, no issues either...
I have 2. One had NO issues at all. The other one... well.
It stopped reporting motion after the update. So I followed Bobby's instructions.
The "configure" route did nothing. So I excluded it and now re-included it. Still not working. Here is the output from the log of the device now when it senses motion:
I see three motion active events in a row, is that it?, no motion inactive? (sensorValue would be 0)
