The built-in driver is for the z-wave version, so it will not work for the zigbee version. While, as @marktheknife notes, the zigbee version hasn't worked for many users, it has for others.
You may wish to to try the SmartThings driver ported by @rfg81 that is available in the post linked below. That said, if it were me, I would exchange the zigbee version for the z-wave version, which works really well with the built-in driver.
PSA for folks that have this device. CO alarm detection is not on by default. I did not know this and did a little research. CO alarm detection is turned off by default because it apparently will shorten battery life somewhat. How much, I do not know or care. I want CO alarm detection. I think that this is very important. Here are the instructions to enable it and how to check and verify that it is enabled.
CO alarm audio detection set up. • • • • • Press and hold both the programming button and the tamper switch for 10 seconds. Remove and replace the battery. On battery replacement, watch the LED light. Look for a RED, RED, GREEN blink. If you see this, the device will listen for CO Test devices to be certain. NOTE detector alarm condition. When detecting both CO and smoke alarms, you may shorten battery life. Battery levels are supervised by most hubs.
