Show as a officially supported device on the forum but not in the dropdown -- Any guidance appreciated
I just replaced my older Ecolink Tilt Sensor with that same one and I'm using the Generic ZWave Contact Sensor driver successfully.
deviceType: 4
inClusters: 0x5E,0x86,0x72,0x73,0x80,0x71,0x85,0x59,0x84,0x30,0x70
outClusters: 0x20
deviceId: 3
MSR: 014A-0004-0003
manufacturer: 330
I got the original long before I added a Linear (GoControl) Garage Door Opener device, In a case of Belt&Suspenders, I use both to completely confirm it's closed!
perfect.. thanks
Just joined the community, and am now getting my devices added. I've got an TILT-ZWAVE2.5-ECO device that has been working great with ST over 18 months. As noted by others, the device is listed as compatible, but unclear as to which version of the device is actually compatible. After more than a dozen tries, the tilt sensor was finally discovered by Hubitat. However, this morning, the sensor, and all other information on my device seemed to have been lost - location gone, device gone, etc. I've tried to add the tilt sensor again, but with nearly a dozen attempts again, I'm having that sense of frustration come over me, doubting the purchase of the Hubitat. I've basically started over, but am at a loss as to how to get the tilt sensor reconnected to the Hubitat. Any help would be appreciated.
Here is a snippet from the log that shows the sensor having been connected as a generic z-wave contact sensor:
dev:12019-02-17 02:12:58.516 am debugparsed 'zw device: 03, command: 7205, payload: 01 4A 00 04 00 03 ' to [8002]
dev:12019-02-17 02:12:58.425 am infoGeneric Z-Wave Contact Sensor battery is 80%
dev:12019-02-17 02:12:58.259 am debugmsr: 014A-0004-0003
dev:12019-02-17 02:12:57.041 am warnconfigure...
dev:12019-02-17 02:12:56.735 am infoinstalled...
I've done a reset on the Hubitat and started over, since the tilt sensor was the only device I had added.
In reviewing the logs, it looks like the logs might be in UTC? Is there anyway to set the log time to local time, as it is easier to troubleshoot when times are local...
Trouble Including ANY ZWave device usually means it's not Excluded.. yet.
That Tilt sensor is relatively easy... go to Hubitat's General Exclude (settings: ZWave: Exclude). In a 2nd browser tab, open live logs. (Right click Logs on the left, open in new tab) Open the tilt sensor and remove the battery for at least 5 seconds. Start Exclusion on Hubitat, insert the battery, close the cover. Live logs should show "unknown device excluded."
After seeing the log entry, you can proceed with Inclusion.
@csteele - wow, thanks for the prompt replay and steps! I've been reading a lot from the community, and I'd have to say that the support and responsiveness is far superior than ST. Glad I found the community for Hubitat. It worked just as you stated, so again, thanks!
