Best I can tell fan minimum on time is not exposed in the Ecobee driver and is not available as a custom command. The two choices for fan speed are Auto and On. I can create a custom command using setThermostatFanMode(off) that will turn it off but restoring it to Auto leaves the fan speed at 0. I tried a couple of ways to using that to set it back to the five minutes I want but had no luck. I did come across this parameter in a Home Assistant thread. fan_min_on_time. I wonder if it would be possible to expose it in Hubitat?
This app exposes that and a lot more - [RELEASE] Universal Ecobee Suite, Version 1.8.01
I use one the ecobee Suite Smart Circulation app that is part of this suite to vary the fan minimum own time setting according to the temperature variations in my house.
