Ecobee configuration tags
Im using a C8 with ecobee enhanced thermostat. I see many tags available in tge device driver. However, the ecobee has limited tags on the ecobee phone app, but locally it has many settings that are only available using the local thermostat display which are used for configuration/setup, but not available on the iphone app or the hubitat device driver/app.
So are these hidden tags such as threshold, schedules, temp deadbands, min/max compress runtime, off timers, etc not exposed to the hubitat driver/app? emphasized text
Installation settings - such as threshhold, deadband, minimum compressor/furnace runtime, are not exposed in ecobee's cloud API for security reasons. That's why they are not available on ecobee's app either.
BTW, maximum compressor/furnace runtime is not available as an installation setting for obvious reasons.
understood, thanks for the response
