setSchedule isn't supported with Ecobee.
I am getting this error in the logson the motion sensors:
2018-11-16 12:38:59.381 pm errorjava.lang.NullPointerException: Cannot get property 'debugLevel' on null object on line 400 (generateEvent)
Does not seem like this port works to change ThermostatProgram (ie. Home, Away, Sleep) the only one that works is resumeProgram.
Any chance this will be updated???
I get the following errors when attempting to change ThermostatProgram:
java.lang.NullPointerException: Cannot get property 'holdType' on null object on line 2564 (asleep)
setThermostatProgram(Sleep, null, 2)
A big warning to everyone....if you ever go to restore a backup, you will lose your ecobee connection if your are using ecobee suite and the only way I figured out how to get it back is to remove the app and add it again. The problem is the token is expired but you aren't able to force the app to ask for it again once it is entered. So, i was stuck and had to remove and readd it.
Just another reason to go to the Centralite Pearl as soon as Dashboards 2.0 is released.
