Hi I have door and windows sensor, and whenever there are open echo speaks si setup to make a sound on an alexa device.
It has a few options to select. but can we upload or setup something different? its like it has sounds of the 90s? no offense haha
thanks in advance
You can include sounds in a SSML string message
See:
You can see a lot of the sounds at:
https://m.media-amazon.com/images/G/01/mobile-apps/dex/ask-tech-docs/ask-soundlibrary._TTH_.json
thanks, do you know how i can use it?
I may have to check with Tony if this requires an updated skill...
hi, any news on this? it is working good now. but it sometimes takes too long to play the sound. do you know if there is a solution for that?
Need to show commands and logs to see....
Need logs for the action and echospeaks main app
