Eaton driver rf 9501
I just checked out the list of drivers for eaton aspire switches. I found a few for eaton switches, but the generic driver I used does function, at least as much as turn on/off. But the current state doesn't update automatically. I also checked the wiki drivers, but I get confused at the web site, there's just too much to learn!
I saw that many folks had problems with GE, but mine are working a lot better than the eaton ones, no problem with status updates, but the GE's are zwave+, whereas the eaton ones are not.
I tried the z-wave poller app, but none of the switches show on the drop down list. I saw a driver for a 9601, but mine are 9501. I think it's just a style difference, but not sure. I didn't try that driver, mainly because I don't know how to change a driver. I am using the hubitat dashboard. Do I have to exclude them, then include them? Once i find out how to do that i might try the 9601 driver. A few years ago I swapped all of our light switches to the cooper ones because we liked the wave style. Either they didn't have z wave back then or more likely, i just didn't know about z wave. to replace them all with eaton zwave switches would cost a small fortune. not sure how i will handle the future, but i sure would like to get my current eaton zwave switches to work so i can control a group with them in it.
@TRJ That is not a z-wave plus switch so you would need to poll it to get it's state using the z-wave poller app
The "legacy" Z-Wave devices (prior to Z-Wave Plus) don't report back to the hub, so you need to poll them for state changes if physically actuated. You can change the driver type to Generic Z-Wave, and they will likely be available to the Z-Wave Poller.
ok, i think i just changedthe drive to generic z wave switch. didn't realize it was so easy. now the status updates. now i;m gonna try to control the group and see what happens.
thanx for the reponses
I have quite a few 9501 switches in my install. I have all set to Generic Zwave Switch. They all report manual on/off events to the hub. Also, my RF9534 dimmers report on/off/level changes without polling. I'm guessing Cooper/Eaton started some of the Zwave+ stuff early. Also reports digital or physical activation. These are some of my favorite devices. Also has the unique feature of programmable off delay. You hold the off for a couple seconds and a timers starts that turns the lights off x-seconds later.
shamless plug-really cheap
The 95xx are Z-wave devices. The 96xx are Z-wave+.
The Eaton devices were originally designed and built by Cooper. Eaton bought Cooper about the time they were changing over to Z-wave+.
Hi,
I am in a bit of a bind. I have Eaton 9540 and 2 9542. I have used Eaton driver and association seems to work just fine. The issue I am having is that when I put the device on dashboard, I can not see the changes in a dashboard after the level is adjusted. I have tried the application for polling the device but it can not see the dimmers. Generic dimmer driver does not seem to work and I loose associations. Please help with any ideas.
Thanks,
ALexV
Are you not seeing an adjustment made at the dimmer? Do you see the change on the device page?
@TRJ did you ever get them to work? I have some 9501's and the same problem you described in your original post.
You need to implement the same solution that was described. Z-Wave devices do not report physical status changes back to the controller (hub). Therefore, they need to be polled. Setup the Z-Wave Poller app.
I read that in an old post. I set up the pollen app but the switches don’t show up in the app. I was able to get an older out setup in the poller app though. I’ve also done a factory reset on the switch. My other switches are still paired to my Vera for now.
Gosh, that was a couple years ago, not sure now what did to get it to work. I’ll have to look over my notes from back then (if I can find them). I know I got them to work but I think I loaded a generic driver, but not entirely sure about it.
I’ve tried using one to remotely control a second porch light and there is a 3-5 second delay after switching on/off the control switch. I can’t seem to get some of the remote controls to work. If I could do some if/then programming I could get it all to work but I’m too cheap to pay a monthly fee. Wish I could purchase a program like that one time and use it as much as I need.
