I've got a couple issues with Easy Dashboard. If I'm missing something, please let me know.
First of all, unless I expand the tile to twice the width, I don't see the full label. Usually the first 3-5 letters. So it makes it hard to even tell what it is.
Second issue is with a temp/humidity sensor. For temp, it spells out temperature (in all lower case at that), unless I have it as single width, then it says "perature...". But for humidity, it just shows the number without what the number is. I know it's % RH, but can that be added back in? And be able to eliminate the word Temperature?
And the last thing (at least for now) is I have a graph on one dashboard, but it won't show up on the easy dashboard. I get the red square with the
