Earthquake Early Warning Automation?
Since our phones (at least in California) now give us a heads up a few seconds prior to an earthquake I was wondering if any thoughts have been made to extend this to home automation?
For instance, prior to an imminent earthquake of a defined threshold (e.g. > 6 magnitude) I can turn on my lights, send a TTS alert, turn off anything that moves (e.g furnace, AC, fans).
It appears that they have strict guidelines around who gets access to this data: ShakeAlert® Licensing Center – ShakeAlert but if there is interest from the community perhaps we can figure out a way to reach out to get something like this developed?
Reading over the material they provide a couple of thoughts:
  1. Implementation would entail establishing a connection to a data feed and ingesting an XML string when provided. Not a herculean task, but would require an always on external connection.
  2. Easiest hub only way to implement would most likely be an app to do the connection and XML processing, and a virtual device for use with RM, etc.
  3. May not be their usual or preferred working methodology as it appears that they are more accustomed with working with a central provider (think phone or utility provider with a central registry of customers) instead of a distributed system. This would require an exception to their 6 max connections.
That being said I will probably send an email to the USGS Lead, Robert de Groot rdegroot@usgs.gov, to inquire as to his thoughts.
I'd look at using something like tasker to scrape the alert on a phone and send it to your hub. While HA has a feed for earthquake data I don't think it's realtime.
Was thinking the same thing...for Android users this could be the most efficient/direct way to automate.
Thanks, please keep us posted on the response.
Sounds like we may need to host some sort of relay service somewhere if they’re strict about the 6 connection limit.
May be ways around that if they don't mind each individual getting the LtO or opening up the Evaluator's license to permit individual use automation
@thebearmay - just checking in if you got a reply from The USGS lead
Never did get a response.
