After the switch to standard time Sunday morning all of my Hub Variables that are date-time type were set one hour earlier. I don't remember this happening before at the time change.
My rules change the sun related variables daily as sunrise and sunset change.
All the other date-time variables should remain the same.
Is there a configuration for DST that I missed? Or is this a bug/new feature?
I know you marked this as solved, but just in case my experience last year helps. I used to set my time variables just after midnight - and when the clock change occurred, my times would be off an hour. I then changed my time variable rule to run AFTER the clock change (I now run it at 4 AM), everything worked fine.
