Does anyone know what device I need to put in to monitor that a dryer is finished it's cycle? Dryer is 240vwith the big plug.
Thanks in advance.
I use a ST multisensor on my electric dryer. Will remain active while itโs running and then I have a RM alert when acceleration stops after 2 minutes.
Where exactly do you position that device?
Is it like the AeoTec Multisensor?
It is the one that uses a coin battery but I converted it to 2 AA batteries.
I have the sensor and battery pack Velcroโed to the top back of the dryer.
Actually, I do happen to have the AeoTec multisensor (which I'm using as a simple motion sensor). It's on the CSteele driver, and that shows a state variable of "acceleration". So, I'm going to put it on the back of the dryer, and give it a shot.
Thank You!
Iotawatt.... Every time...
